Easy...
pry off the horn cover.
remove nut.
install steering wheel puller.
pull steering wheel.
Two inexpensive tools you should have are a steering wheel puller, and a lock plate depresser tool. Once your wheel is off, if you need to get deeper into things you'll need to remove the lock plate...
I keep my steering wheel tools in a small cooler bag.
I did it by myself without the tool MANY times back in the day...NEVER again, it's a pain in the arse... from removal to install... tool is worth eleventy x's what it costs....
