I've been trying to fix my steering issue without asking for help on this site, but I give up. I have about an inch of slack/play (whatever it's called) in my steering. I have to constantly steer left, right, left, right just to keep my K5 out of the ditches. Okay, that may be an exaggeration of sorts but not much. Here's a list of all the things I've replaced/fixed to rule out my issue. Any help would be greatly appreciated.
I forgot to mention that my steering column is a tiny bit loose. It's the common issue where the 4 bolts deep in the column loosen a bit. However, it's not that loose, and I can't imagine that would make that big a difference on steering. It's on my list of things to fix, but I just hate tearing into steering columns.
- replaced control rod end
- replaced both drag link ends
- replaced upper and lower ball joints
- had the front end aligned
- replaced the steering stabilizer shock
- replaced the intermediate steering shaft with the typical XJ swap
- tightened my steering box adjustment screw 1/2 turn (clockwise)
- re-torque wrenched the leaf spring U-bolts to 150 lb-ft (in the recommended 1-2-3-4 pattern)
- repacked the bearings in grease and torqued them using GM's specs
- replaced all 4 tires (just because they needed replacing)
- replaced the power steering pump
- replaced the rubber eye & shackle bushings with greasable poly bushings
