family-man
Registered Member
Took it in to have the column wobble fixed. It is better but not gone. Now where do I go from here?
If you're talking about a tilt steering column that was loose and wobbly and you paid someone to fix it and it still wobbles they did not do the job correctly. It requires a pivot pin puller in order to take the column far enough apart in order to tighten all 4 bolts that become loose. Without the pivot pin puller you can get to 3 of the 4 bolts and you "might" make it tight enough to not wobble but not a guarantee.
they tightened the four bolts. when they put it back together they are saying something is loose below the tilt bolts. said about 8-10 inches blow the tilt joint. said tightening took out bout half the wobble. done by chevy dealership
Did mine a few years back and it never tightened up completely and ended up becoming really loose again. The internal column tube (area that contains the tilt retainer) had sheared/fractured. Is your shifter also binding? How long was it loose? Apparently, if the 4 bolts that tighten the retainer are left loose for a while, they will shear the column over time. You may need to get a new column tube and start over.
Here's a good link. A pic of my sheared tube is on post #38 of this thread:
http://coloradok5.com/forums/showthread.php?t=300350
