Steering Y-Link Adapter!
Gravel Maker
Sacramento, CA
This piece solves the clearance issue that so many of you have. We have created the components to make a Y-Link while using the offset TRE. This gives you the clearance you
require with the benefits of Y-Link steering while retaining the full adjustability of a standard Tie Rod. This Adapter is made from 4130 Chromoly Steel.
But we don't stop there! With this kit we add "The Cure" to
Tie Rod roll. The Cure! - RuffStuff Specialties Read more about it here.
These two items combined are revolutionary in steering. Completely
new ideas! So much so that we have patented both items. These have been tested on our JK, and employees TJ, and anothers F350. Now on all 3 rigs we can drive with no hands! Have you ever owned a jeep that goes straight without constant correction? Enough said!
Y link adapter 18TPI (TRE threading) - RuffStuff Specialties
