Eric M.
The steering box keeps loosening up on my 91 Burb. D60 front, stock springs, 33" tires, newer AGR box / pump and steering components, everything seems in good condition. Truck is street driven only. I get about 4 months (4K miles) between needing to retighten and it get's pretty loose in that time. You know when it needs to be tightened ... it doesn't steer very well when the box is flopping around on the frame rail! Last go around I installed an ORD brace and red lock tite on all bolts.
Any ideas or should I make this regular maintenance when I change the oil.
Thanks,
Eric M.
Thanks,
Eric M.
