So I know that they are hard to find but where can they be found? I know that LMC has them, but I want a better quality replacement.
They're almost identical from 1955 thru 1987. Unless you absolutely insist on new ones, look for a bed that's been turned into a trailer, that's where I got a set a few years back. They were actually straighter than most of the newer (and higher priced) ones I'd looked at.
Yeah, I knew there were some differences, but as long as this isn't an absolutely correct restoration and the bolt holes line up, does it really matter?
Too bad it's so far and shipping would be a bear, I'm sure I could scrounge something up around here. By the time it got to you, it would probably cost as much as a complete bed![]()
if it costs more than $300 then forget it. I figure that since a new reproduction fender is $200 and then shipping is about $100, $300 sounds the max.
