Still running cold?
Bad thermostat? Tons of bad ones out of the box, especially if they aren't Delco pieces.
I replaced the tstat, and it didn't change anything.
Plus, with a bad tstat, it would just warm up slow, right?
I just used one of these when I did my first exhaust
http://store.summitracing.com/partd...&part=WLK-33240&N=700+-47311+115&autoview=sku
It works pretty good. I did a whole exhuast with it and there was no leaks. But now I have a mig welder so I just use that.
Adam
Thats what i am guessing is going on. Now to check if its bolted or welded on....and proceed from there. If its welded, ill prolly have a shop replace it, as i don't have a mig welder, and can't stick weld well enough to do it myself. Thanks!
No, they tend to stick, creating problems with temp spikes instead of smooth operation.
T-stat is what controls engine temperature, period. Anything else bad in the cooling system equals overheating.
