I'm stuck until I get this worked out. I've got this 10 bolt with older 8 lug, Dana 44 external hub outers I'm trying to get back together. Put all new bearings and seals in driver side spindle and hub and its fine.
The passenger side is killing me though. I've had it apart and back together a few times and there is always some kind of metal on metal binding going on. Checked to make sure the races were all seated good, picked up another set of bearings because I thought maybe I got something in the first set of new ones. Double checked the part #'s to make sure I got the right ones.
Looking at it today I notice some small metal shavings in the bottom of the backing plate. Then look closer with a light at the inner hub seal and there's impressions from what has to be the 6 studs/nuts that hold the backing plate and spindle on.
How the heck is that happening? The only thing I can think to do is use some small washers as spacers between the backing plate and spindle, but that doesn't seem like a good idea.
Neither of which sounds very appealing right now - especially since I have no idea what the problem is.
