Are you running a mini starter? There is nothing wrong with the stock starter I have other then that it is so heavy. I installed a support brace which someone had taken off.
I'm thinking however that the mini starter would be just as good and better since it would be light weight. I'm still on the fence about swapping.
..about 5 times,before I finally got one bolt started..
