Wanted Stock 4 Bolt Flat Flange NP203/NP205 Front Output Yoke
GonicGM
Seacoast New Hampshire
Looking for one or two stock front 4 bolt flat output flanges/yokes from NP 203 or NP 205. I believe GM and Dodge are the same. The flange retaining hardware often loosens and these flop around, result is spline wear. I'm looking for one or two with clean seal surface and unworn splines.
I might have what you want. I'll pull the bolt/spline/ and pilot specs and get back to ya
I've got a 30 spline unit if you need one. Gm 205 clean pullout.
looks correct. Spline wear is subtle and must be washed to inspect. Interested in good one, don't want same thing I already have. Spline wear is taper and more toward nut and washer. Prices?
