Found stock 80's 80 psi diesel oil pressure gauge
sweetk30
Back to play nice .
in the back of your brain
looking for a 80's diesel oil pressure gauge in the 80psi max range .
looking to swap mine out as the new engine and 5-30 oil have her maxing a lot at 60 psi .
i can get a new sender local unless you have one and its new / like new / good working no leaks .
thanks and let me know .
Pretty sure I got that. I know I have a 100 psi if you want one of those.
i think i looked for the sender and being from a med to hd series there a bit more funky and hard to pinpoint one .
i figure 80 psi is diesel spec for our c/k trucks and stupid easy to get the correct sender .
If I ever go to lantzs, they always seem to have those. Picked up two tach clusters last time I was there...
I was asking $40 for the whole cluster, I could do $40 shipped. It came from a parts truck that was parked for transmission issues in ~2010. The gauges all worked at that point but it didn't run when I acquired it to test them. I can pull the clear lens off this weekend for a better picture of the gauges.
The clock works and looks good and the housing is actually in great shape. But every other gauge is rusting.
