RockBottomRacing
Did wheel bearings and hub/rotor assembly yesterday, also did the needle bearing behind the spindle. Assembly went well, but now I can’t get my Auto locking hub back in! I can get the snap ring to the edge of the hub bore but it won’t budge any further, never had this kind of trouble with manual locking hubs, what gives?!
I’ve followed the correct torque procedure out of the service manual, and the outer bearing is all the way in the bearing race. I thought maybe I put too much grease in so I pulled some out and tried again and still nothing. The hub is not hitting the nut, in fact from what I can tell it’s not hitting anything at all behind it. You can see in the grease where it stops and it stops with plenty of room to get the hub back in where it belongs. I need this thing on the road ASAP, so if anything has any tips or pointers it would be much appreciated! I’m even to the point where I might call 4 wheel parts about getting some warns for me...here’s the pic where I’m at currently.
91 Suburban V2500, GM 10 Bolt. AcDelco rotor/hub assembly, timkin bearings and seals.
Thanks guys!
Thanks guys!
