stock driveshaft flange
All i know is that the front shaft uses 3R or what's known as S44 U-joints.
I can tell you that there is a mating 1350 CV-joint available because I run that flange on the front and rear of my T-case and had the rear driveshaft built to match. The only name I've heard for the flange is "Saginaw CV flange".
