I read about how some spring a leak and have destroyed motors.
I know the lines leak, never seen a cooler leak.
Sure its GM engine coolers you are hearing about?
Dodge has one for the transmission that is a real horror. They regularly rupture internally and fill the transmission with coolant without any symptom until the transmission stops working.
Haven't had a problem with mine, lines have never leaked, but my adapter just started spewing oil in the last couple of weeks.
Either way, that sh*t was not cool.If I remember correctly, the factory rivet that attaches the oil cooler assembly had broken, allowing the cooler to vibrate slightly and caused it to fail...
Good point. My rivets had broken as well. I had re-bolted everything down months prior to the failure, but....
After mucho searching on CK5, I came away with a net impression that unless the vehicle is a relatively heavy tow vehicle, an aux. cooler may not be worth the failure liability. Being able to look over at a cooler that failed obviously punctuated my decision...![]()
Must have a weird fitting header, mine work fine and can change the oil filter without any troubles as well.
As forr the oil cooler, I like mine, never any problems, I did change out the adapter gaskets/o-rings when the motor was replaced, but the hoses and cooler still work great. Just like components on the rest of the truck, it won't last forever and requies perodic inspection and repairs if needed.
