stock head light wiring upgrade
Yep, did it to one of my trucks. The other one has excessive lighting already =))
http://coloradok5.com/forums/showthread.php?t=164429
I'm pleased, with noticeable results for a cheap & simple project. Of course I'm a closet EE, so my definition of 'simple' may not be yours.
You can buy an off-the-shelf harness, if you're so inclined. I didn't see the point, as in my case there's a battery on each side so it was easy to wire up.
-- A
It makes all the difference in the world!
But be ware, if you drive your truck a lot at night, it does shorten the bulb lifespan.
Search for threads by me, and you'll find mine, with photo comparisons.
Totally worth the change. Especially the 4 high conversion. Makes SUCH A DIFFERENCE, do it!
Found my little writeup:
http://coloradok5.com/forums/showthread.php?t=216590&highlight=headlight&page=2
