gonner Registered Member Premium Joined Aug 30, 2008 Posts 67 Reaction score 0 Location Gray,Ga. Mar 23, 2012 #1 Who has one or where to get one?Another question is does the bracket very between years or stays the same?
imiceman44 Hoarder extraordinaire Premium Joined Aug 5, 2002 Posts 32,822 Reaction score 16,933 Location Lincoln, CA Mar 23, 2012 #2 gonner said: Who has one or where to get one?Another question is does the bracket very between years or stays the same? Click to expand... I am not sure what braket you speak of, the part on the firewall that the hydroboost bolts to is the pedal assembly and it goes from the inside.
gonner Registered Member Premium Joined Aug 30, 2008 Posts 67 Reaction score 0 Location Gray,Ga. Mar 23, 2012 #3 I'm changing from power to hydro.Is there any diagrams on ck to look at about that bracket from the inside
sweetk30 Back to play nice . Premium GMOTM Winner Joined Nov 1, 2004 Posts 43,003 Reaction score 25,453 Location in the back of your brain Mar 23, 2012 #4 all you need is the unit its self and the brake pedel assembly that bolts to firewall on inside and under dash. the brake pedal has the pin for the rod in a diffrent place. otherwise unbolt vac brake booster and bolt on hydro boost unit.
imiceman44 Hoarder extraordinaire Premium Joined Aug 5, 2002 Posts 32,822 Reaction score 16,933 Location Lincoln, CA Mar 23, 2012 #5 gonner said: I'm changing from power to hydro.Is there any diagrams on ck to look at about that bracket from the inside Click to expand... Well you will need the pedal from the hydroboost setup truck. If you are still looking for a set I should have a set with the pedal.
