Stock Prop Valve Fitting Size?
cbbr
1 ton status
High velocity, Low altitude
I think that I'm going to use SS braided hose on the rear. Anyone know the stock fitting size on the prop valve?
1990 3/4 ton Burb.
1990 3/4 ton Burb.
Note that 1990-91 have that odd rear-wheel-only ABS. Which you might well want to remove while you're in there. :thinking:
I don't know if it has a different combo valve; I *thought* they all had the same fittings, but I donno 'bout that ... thing. (Can you tell I don't like the RWABS? ;) )
-- A
