B Ben B. 1/2 ton status Joined Sep 1, 2005 Posts 350 Reaction score 0 Location Central PA Feb 22, 2008 #1 I have 4" lift on my K10 at the moment. Could I use front zero rates and move the axle forward 1" without messing up my steering?
Hogback Fabrication 1 ton status Vendor GMOTM Winner Joined May 26, 2003 Posts 10,818 Reaction score 1,421 Location New Castle, CO Feb 22, 2008 #2 Do you have crossover or stock steering?
B Ben B. 1/2 ton status Joined Sep 1, 2005 Posts 350 Reaction score 0 Location Central PA Feb 22, 2008 #3 38377k5 said: Do you have crossover or stock steering? Click to expand... Stock steering and 0-rate offset?
Hogback Fabrication 1 ton status Vendor GMOTM Winner Joined May 26, 2003 Posts 10,818 Reaction score 1,421 Location New Castle, CO Feb 22, 2008 #4 There is probably enough adjustment in your draglink to let you move the axle 1" forward. This will make the draglink shorter and hence make its performance offroad that much worse.
reddog64 1/2 ton status Joined Nov 9, 2000 Posts 3,324 Reaction score 0 Location Federal Way, Washington Feb 22, 2008 #5 i did 52's with zero rates 1 inch forward... I have crossover.. .just not installed yet... I wouldnt even think about doing more than rolling it out of the garage the way it looks right now...
