Not sure I should reply vs. waiting for a new thread, but Rene can move/kill it if not I suppose.
Tach is not wired into anything specific with the injection, except the remote coil. Simple to move the tach wire over to the distributor.
Not sure on the dash itself, the 90-91 cluster housing is different than at least the early-mid 80's stuff, but since the above posts show a tach in the lower left position (which is cast with ribs in the way) it can be done.
As to plug and play, never assume. Burning up a tach dash is a bad idea. Trace the circuits on the plastic circuit "card" on the back of the cluster to compare. The earlier ones had mechanical oil and ammeter, both of which IMO are a bad idea.
PCM is later vehicles, these only used ECM's. On a somewhat unrelated note, not knowing what you are doing with the rig, TBI is far better than a carb for most things...
