Stock Truck ORD List
chalet2506
CK5 Huge Member
Skeddadlin
I'm fixing to call up and order poly body mounts, greasable bushings for my stock springs, 1" body lift, and bolt on steering brace. Anything I'm missing? I realize this is a vague and general type question so please keep the flaming to a minumum.
That could be a loaded question but the guys at ORD should be able to fix you up with what you need.
What do you want to use the truck for mostly?
Mild offroading while camping/fishing. Nothing extreme. I found one of my rear rubber bushings split and laying on the frame the other day, hence the new mounts and 1" lift. I figure I'll go ahead and get the steering brace before my frame cracks. I'm basically just trying to improve things as they break, or before if breakage is imminent.
Leper said:
New brake hoses are never a bad idea.
That's what I'm looking for, stuff I wouldn't normally think about. Complete new lines, or just the soft ones. Maybe I'll crawl under there and take a look tomorrow.
