Stock U-bolts 14FF
Anyway you might know a length? Are you plates over the spring or under the axle tube. I have got several sets for the under style, but are different lengths due to spring packs with more or less leaves and spacers. Let me know. Thanks, Brian
Needing the kind where the plates are on top of the springs, another words the threaded ends of the U-bolts are sticking up. I'm using a stock set of 3/4 ton rear springs off of a 2000 truck. It has 5 leafs plus a very thick overload. I can measure the spring pack tomorrow if that will help?
