xCaliK5x
Well, my brakes on my truck are kinda shotty. I haven't had this truck a month yet. There is probably 10% pad left in the front, caliper hardware is falling out. The lines are too short, so I have to redo the front brakes. Pads, calipers, lines.
The rear is another story. I have NO clue whats behind the drums. Its an early 14 Bolt FF with the parking brake cables that appear to be equal length, and are held on to the backing plate by a couple of bolts. The rear brake line is also keeping me from getting full droop on the axle!
My question is, being that I'm doing the front brakes, the rear also should be done I'm guessing.
Do I re-do the rears from the backing plate out and try and figure out the parking brake?
Do I swap to discs and not have a parking brake? I found a kit online here http://www.twiztedengineering.com/servlet/the-1/Conversion-Disc-Brake-Bracket/Detail for less then $400.
I have a slip yolk 208 so I'm guessing no parking brake can be attached to it easily?
I'm still on the stock booster and master, do I need to change these with the 14 Bolt drums, or disc?
Thank you in advance for helping the n00b oh wise CK5 guru's.
