sled_dog
1 ton status
I'd like to see someone do a big brake kit for all 4 corners. Of course, in crawling how necessary is it?
Stomper said:You know what we were talking about the other day, inregards to my lathe.
I think they just may fit.
cybrfire said:As far as two independent calipers on the same rotor being bad, it's been done in other applications and I can't see any reason it won't work here as well.
jarheadk5 said:Not a problem at all; thousands of commercial airliners and military jets can't all be done wrong. Hell, a lot of aircraft brakes have a separate friction "puck" or pad for each piston in the caliper.
Plumbing in many apps is simple - single line coming from the MC, hits a tee or manifold, and a separate line goes to each caliper. It can be plenty more complicated upstream (anti-skid valves, shuttle valves, etc), but at the wheel it's usually pretty simple.
Drey said:Looks good kert, if not half ton chevy calipers what are then? if you dont mind me askin.
Was common a long time ago in Formula 1.cybrfire said:snip......
As far as two independent calipers on the same rotoro being bad, it's been done in other applications and I can't see any reason it won't work here as well. On the other hand there could be a scenario when one caliper would "hang up" and may cause some problems. That has been considered but since this is a prototype, I'll cross that bridge when it falls down!![]()
SOP guess based on doing these calcs in the past is that the m/c is going to need to be ~1.5" if the pedal stroke isn't to be long. When I get home I can plug this into a spreadsheet I've got and see what it really will need to be.HarryH3 said:Have you calculated the total volume of the dual pistons vs. a single? Seems to me that you'll need a master cylinder that moves a lot more fluid to get both of those to move far enough to get some decent clamping force.
sled_dog said:I'd like to see someone do a big brake kit for all 4 corners. Of course, in crawling how necessary is it?
