A little back ground on the vehicle first. I have a 1988 V10 Suburban. The engine in it consists of a 1990 IROC-Z 350 short block (with forged flat tops), a 1995 Z28 LT1 cam, Vortec heads (the lesser casting), 1.5 roller rockers, GMPP TBI Vortec intake, headers and 2.5" dual exhaust, no cats, no smog pump, no EGR. It has been together like this for a while and ran fine. Before this setup it had ported throttle body swirl port heads and a stock intake, but with an LT4 Hot Cam. It ran fine with that combination as well, the power band was just to small (cam came into power, heads ran out of steam).
Well a few months ago it started having a random cut out. Was no big deal, just annoying. Then it got progressively worse. I finally broke down and installed new plugs and wires, and installed a couple header plug boots. I had found a couple burnt plug wires, and figured that was my whole problem. It actually ran much better after this, so that was some of my problem. Then is started happening again.
It has gotten progressively worse. It has something to do with the how long the engine runs as well. I live three miles from the highway, so if I jump in and drive it to the highway, it runs fine for three miles, then I stop at the stop sign and try to take off. I have to go up a decent hill there, and I've noticed a load will trigger it. So when I go up that hill it starts bucking from the engine cutting out.
Also if I leave it sit and warm up for a little bit, it will do the same thing, but right away.
The odd part is that I found if I merely shut the engine off and turn it right back off, the problem usually goes away.
Suggestions? Questions?
Where do I get the cable to hook up to a laptop? What kind of laptop do I need?
Martin
Martin
