Wife was driving the suburban the other day and when she went to put it in reverse it died on her and would not start.
I grabbed a timing light and multi meter and went to check it out.
I have a fuel pressure gauge on the fuel line and it was still reading 18 psi but there was no fuel spray from the injectors.
I put the timing like on and check for spark.
So I had spark and fuel pressure but no spray. I figured it was one of two things. Either the ignition control module or the ECM. I don't have a NOID light set so I couldn't check to see if the injectors were getting a pulse signal.
Before pulling the ICM out I figured I check fuses but didn't think I was going to find any blown.
Well, I check the ones I thought it might be. ECM1, ECM2 and neither blown. I started pulling the other ones and came acrossed one label Trans that was blown. It is a 10 amp fuse and I replaced it and the damn thing started right up.
I haven't chased down that wire yet to see what it goes to but I thought it was very strange that a fuse label Trans would stop injector pulse.
This is on a 7060 ECM and a 4L80e trans 3/4 suburban, 1991.
