Ok, I've been chasing some voltage gremlins (low voltage, engine cutting out) lately and gave up and dropped in a new Interstate Battery and had my Alternator rebuilt.
I put the parts in yesterday and checked the voltage drop across the terminals. Alternator to battery has about a .1 volt drop on the positive side and about .05 volt drop on the ground side. I'm pretty sure I've got good connections and I cleaned everything up before reassembling.
So, today the voltage starts dancing all around on my gauge from 'normal' to higher and back.
For reference here, the numbers on the gauge are NOT quite correct. (Have changed over time.)
Battery voltage of 12.6 reads:
While running at a normal charge level (~14.5 volts) it looks like this:
What I saw today:
I was able to check with a multimeter and '14' on the gauge reads 15.2 on the meter.
Oh, and I'm pretty sure it is NOT a gauge problem since I can hear the blower pitch/speed changes as the voltage fluctuates.
I'm honestly not sure what to think. If it were a bad connection, I'd expect the voltage to drop, not climb like this does.
Anyone got some insight as to what is happening here?
It doesn't matter if I'm idling at 600rpm or running down the freeway at 2000rpm, it will do it. However, it is intermittent but seems to be happening more and more often.
As usual, any and all help is appreciated!
-Ben
What I saw today:
-Ben
