I'm putting the finishing touches on my axle swap and am trying to put the front drive shaft in. The old 10 bolt used U bolts to secure the shaft. The parts book shows U bolts on the Dana 44 that now resides up front, but they don't fit. Hard to see if the holes are threaded, but I'm thinking the front takes a strap kit with bolts. Can someone advise for sure?
Thanks!
Thanks!
Front and back.
Your best bet may be to find an old axle laying in a junkyard and pirate the straps off them, or ordering them from GM which is surprisingly pricey. Either way that probably will save you some tears in your beers in the future
