straps vs. u bolts
twojoints444
Registered Member
B.C. Canada
whats better for pinion yokes, strap style or the u bolt style? or are they 6 of one, half dozen of the other.
adam
adam
U-bolts are better. The straps wear over time and allow the joint to have slop in the yoke.
so its worth buying the yoke that takes u bolts, or can i mod my existing strap style yoke to take u bolts? if i have to buy a new yoke, how many spline yoke does my corporate 10 bolt 3/4 ton diff take? Thanx
Adam
Yeah you have to buy the new yoke to do the U-joint style. The stock yoke does not have a flat area on the back side and the holes are different widths for the U-bolt. Honestly if you aren't wheeling the truck hard you can buy replacement straps and will probably suit your needs just fine. :waytogo:
