stripped steering wheel bolt
medeng8
AL
I pulled my horn cover off to put a newer steering wheel on and went I went to remove the center bolt, it came off pretty easy, which I thought was odd. I then noticed that the threads that the bolt go on are almost non-existent and smooth.
What do I do? Use a tap to cut new threads? I have never done it before, but I really need to fix this as I dont think its safe to drive now.
find another steering column and replace the whole thing. I think that would be the easiest route to go. then you'd just have to swap in your tumbler or get a column with a key.
I agree, I wouldn't feel safe running that. And if the threads are gone(smooth) you cant really cut new threads unless you go to a smaller nut.
Nope, it sounds liek the damage is on the shaft. I would either:
1. Get a new steering column
2. Weld the nut back on until I could get a new column
