Stroker flywheel/flex plate identificaiton
MTMike
Billings, Montana
My truck has a 383 stroker in it, built up by the previous owner. I've pulled the Turbo 400 out and plan on replacing it with a 465. I need to order the flywheel for the swap, but I'm not sure how to tell if my 383 is built with a stroker kit crank and is internally balanced, or if it's externally balanced.
Does anybody have any pictures or guides on how to tell? The flex plate is still on the engine.
Thanks,
Easy to tell if it's externally balanced by looking for the "balance weight" that will be on the engine side of the flexplate. Most stroker 383's are externally balanced still. It takes expensive mallory weight to internally balance a 383 and most people don't want to spend that extra cash.
4x4hi..i know this, but how come you can't go oppisite where it needs the mallory and remove weight, do same thing? i have a thread coming for you also, its about building a custom engine..i will hail you
If you're talking about an internally balanced engine and removing weight opposite of where mallory weight would need to be the problem is there is nothing there to remove weight from. One side of the crank has a counter weight and the other side is a crankpin for the rod and you cannot remove material from the crankpin and even if you could it is too close to the center of the crank and it won't make a difference.
yes thats what i was thinking, remove material like they do the weight lightning holes making the rod journal like a pipe, but just take out the amount necessary
Yes, it looks like there's a small stick-on weight on the flexplate on the engine side. Could that be transferred to the same location on a new flywheel?
You need a flywheel from a 400 SBC. The 400 SBC is externally balanced and the weight is cast into the flywheel. If the original builder of this 383 balanced it correctly you won't have any troubles. But on the other hand, if he didn't balance it correctly then you're screwed and will have to take the engine completely apart and HOPE that some machine shop is willing to help you get it balanced correctly with a flywheel.
The engine was built by a professional mechanic so I would assume that it's built properly. So the 400SBC Flywheel has the external weight cast into it already and theoretically I shouldn't need to add weights to the flywheel? And if the engine is built properly, and I get the 400 flywheel, it should bolt on and go?
Do you know what year this engine is? Hopefully it's a 1985 and earlier with the two piece rear main seal. If not then you're screwed because the one piece seal main engines use a different bolt pattern and the 400 SBC flywheel won't bolt on.
I'm 99.8% sure it's a pre-86 engine. It's got a driver-side dipstick like my old '79 had. When I had the oil pan off 3 years ago I vaguely remember it being a 2-peice. When I pull the flexplate off I'll make 100% sure.
Thanks for your help & input
People do use them but i would never use one. That goes between the crank and flywheel so it moves the flywheel backwards about .125" (1/8") which means the starter bendix gear engages the ring gear by that much less. Why not just buy the proper flywheel?
I just figured it would help keep the budget in line. I'd rather spend the extra $ and make sure I get a good setup, but I wanted your opinion
I pulled the flexplate off today
Rear:
Front:
Crank output:
I assume the weight on the back of the flexplate is the external balancing weight?
Rear:
Front:
Crank output:
That would be correct. Now go find yourself a 400 SBC flywheel.
Here you go.
http://store.summitracing.com/partdetail.asp?part=HAY-10-132&autoview=sku
http://store.summitracing.com/partdetail.asp?part=RAM-1523&autoview=sku
http://store.summitracing.com/partdetail.asp?part=RAM-1423&autoview=sku
http://store.summitracing.com/partdetail.asp?part=CTF-700180&autoview=sku
