strong enough?
NEK5
3/4 ton status
Ipswich MA
I`m mounting this box on my firewall for my battery. On the inside behind each bolt I`m using 2"x2"x1/8th" square spacers to add strength to the mounts, so it doesn`t want to pull through. My question is, will the top two bent over tabs be strong enough for the top mounts? I`ll use those to points, and two in the middle of the back of the box.
Heck yea, You could hang your engine from that !!!! HA HA You'll be just fine. Good fab work by the way !!
Just what I wanted to hear. As far as the fab work goes, thank AFCO(got it from summit), as thats who made it :p: I should`ve just went along with it, started getting that warm fuzzy feeling when I read that, then I realized I bought it :o Some day....
Drill your holes as close to the bend as possible and use a good quality, preferably thick washer. Keep the weanher on the flat surface just right off the bend. If you drill a hole out at the small end it may bend out over time and off road bouncing around.
Ben,
The hold-down is just as big of an issue... I've seen batteries fall out of perfectly strong battery boxes because the hold-downs were underengineered. A battery falling face down in the engine compartment is a great way to start an electrical fire.
Offroad trucks need a lot more than a simple set of fingers over the lower battery flanges... once you start landing those big-air jumps everything need to be stronger than you realize. :D
:usaflag:
