Stronger than a D60!!
Convert it to D44 disk brakes and you'd probably save about 200Lbs...
It would get a little narrower too.
What's the R&P ratio on that thing? :dunno:
I wish i had a pic from when I was at Caterpiller in Peoria Illinois. The axles on the back of the big dump trucks are crazy.
Back when I worked at the truck transmission place, we had a huge Cat axle from some kind of haul truck.
24 inch ring gear!
The pinion looked about as big as a 5-gal can, and had to be hoisted into place. The housing looked to be bracketed for a 3-link suspension setup. Multi-disc wet brakes inboard of the planetary hubs. The whole assembly shipped out at almost 6000 lbs...
