struts on Pontiac G6
70jimmy
3/4 ton status
Staff member
Moderator
Released from Pueblo, told I belong in Southpark
I am getting ready to front struts on a 2006 Pontiac G6 GT. Car has 190,000 miles. Curious about whether I should buy the whole kit (strut, coil spring, mount assembly) or just the strut itself. Planning on keeping the car for the for a while yet. Opinions?
The QuickStrut is so much easier to put in. No need to mess around with compressing the springs and reusing the old mounts. Usually the mount is toast at that milage too.
I'd get the struts with new springs already installed,for the above reasons,and the original springs are fatigued by now,if not broken--plus if you try saving money having your old springs re-installed,most places with a spring compressor want about as much to make up the difference in buying "complete" struts vs a strut only..
I replaced the struts only once with a rented spring compressor from o'reilly's, no charge just deposit. But yep gonna order the setup and do it. I need to do the rotors and pads anyway so do that all at the same time. Thanks for the advice guys!!
My experience with replacement springs is that they rust quick, while factory ones have that thick rubber coating. GM has tons of variations in the spring rate and static height on coils, so quick struts may be changing things from stock (could be better or worse, I suppose). The springs last virtually forever, but I did have one break once on a car, don't know why. Even the struts last like 150,000 miles or more, until the tops rust through or you dent them up somehow. I would take a high-mile stock strut and spring over a cheap new one. The upper strut mounts do need to be replaced periodically, as do the control arm bushings and sway bar end links. Usually when people say "my car needs new shocks" they actually have a blown bushing or strut mount making noise.
I do see cars regularly with a back tire hopping on the freeway because the damping is just gone. I always wonder what that feels like inside the car and why they don't seem to care. Handling has to be terrible when tires are only touching the road half the time!
Did some AC Delco replacement strut/spring. Bought about the most expensive street performance ones. Car feels way better now. Also put on some drilled slotted rotors and ceramic brake pads. Big improvement. Next I will upgrade the rear shocks and check on the rear brakes again.
