pch858
last week I purchased my 1st GMC Jimmy am not sure if it's a 1980 or 81 the pink slip says 80 and purchased an 81. The individual or purchases off of said his friend left it in four-wheel drive and then he didn't drive it for 10 years or so because he couldn't get a California smogged. I was told by somebody if I drove around for about a half hour or so to warm everything up I could probably shifted out of four-wheel drive back into 2 wheel. But with no luck it's still an four-wheel-drive low. The truck has automatic locking hubs and this weekend since I'm on spring break I'm going to swap them out for manual hubs. But I'm not sure if that's really going to fix the situation. Could someone help with some suggestions on what to look for or what the problem could be quite rebuild the transfer case etc.. There are some other electrical problems as well like the power locks when I hit the switch on the inside the locks will not unlock and even when I tried to manually pull the locks up they are stuck. So it seems like him to have a lot of little stuff to do as well over my spring break. One of the other things was also lowering it back to stock height and switching out the gears because I believe they are 4.88 and I want to go down to 3.73 because it is going to be a daily driver. Thank you everyone for your help and any suggestion since this is my 1st Jimmy before this I was a Volkswagen or Ford guy and I'm really excited about this truck.
