Ok so I've got a ff14bolt with 4:10 gear ratio , also have a Dana 44 with the same ratio.
I was thinking of putting 4:56 gears in the 14 bolt. Should I do the same to the 44 baisicly keep it or find a Dana 60 ? So baisicly not sure if I should run what I have up grade the rear and front axel to 4:56 or find a Dana 60 and match the rear @4:56 Also what will my rpm be 700r4 trans running 35s but possibly going 38s just not sure which route I should take .
