Jay Bird
Registered Member
89 blazer with 350 and I can't get filter off. I have it all broke off but about an inch and all the insides are out. Have tried everything I know.
Help!
Jay
Help!
Jay
Help!
Jay
There are only two things that can hold a filter on like that. Either it was crossthreaded to start with and it was forced on, or the rubber gasket has bonded to the engine.
I stand corrected.man oh man....... until you have had to deal with a filter that was installed with locktite........ you HAVEN'T LIVED!
Shouldn't have cut it off...coulda done the ol' stab it with a screw driver for a good handle trick.
Yes it's no fun when the gasket sticks and you don't notice til you start the engine and oil begins spraying everywhere.Way to go. Forgot to mention one thing. Double check and make sure that the rubber seal came off with the old filter.
Even on filters that came off easy, I have seen the seal stick to the truck. And they always leak when you put the new one on over the old one.
Done that more than twice
