Blue Stomper
Registered Member
Okay- I pulled up to the light tonight and pressed the gas a little too hard- All of a sudden I heard a clank and it felt like the shaft feel off. Then after giving a little gas it would simply rattle the shaft a bit and move the truck in extreme slow motion. I got towed home and started checking it out more. The shaft is in place but now when putting it into gear, there is no more clank- instead the shaft spins just barely when giving throttle- as if there is minimal contact with the transfer case and the shaft. Trans fluid is full and I smell no burn on the dipstick. I'm thinking its the Transfercase but my neighbor who had a K5 thinks its the torque converter. I have an 87 K5 350 TBI bone stock with 97k miles. Everything runs 100% and I hope you guys can help me out- I'd rather not let my wife talk me into junking it- love this truck.
Oh and about 50 miles before this happened (2 weeks ago) i used the 4 wheel drive during the snow and everything was fine. About 100 miles ago the cat back exhaust had fallen off (rotted) and I had to drive about 20 miles home while the pipe was banging against the shaft. After I cut out the pipe the truck was fine. I wasn't sure if either of those could be related to my problem.
I don't know 4x4 drivetrains very well so feel free to talk to me as if I know nothing. Oh and the problem is the same in 2 or 4 wheel drive and in forward or reverse.
thanks
thanks
