Brady Foster
Newbie
Hey y'all, about three years ago my dad @Brandon Foster and I finally "finished" our restomod project (build thread here). Of course what project is ever actually finished
. But over those last three years I've daily driven it most of the time. Around spring of 2023 I had an entire stud shear off (only going about 40mph) and since then frequently checked the lugs to ensure they were tight every couple trips around town. Often the lugs would be a decent bit out of spec and the front studs would be incredibly hot to the touch. Finally about a week or two ago I was checking the lugs again after a quick drive and completely sheared a stud off. After taking off the wheel and rotor the studs looked completely rusted where the rim sits against the rotor and grooved out like they've been worn down over time. (see the attached picture below). So what do yall think the problem could be? The rims are the original ones from before the restoration.
If this was already a thread I apologize, I couldn't find another one covering a similar issue.
. But over those last three years I've daily driven it most of the time. Around spring of 2023 I had an entire stud shear off (only going about 40mph) and since then frequently checked the lugs to ensure they were tight every couple trips around town. Often the lugs would be a decent bit out of spec and the front studs would be incredibly hot to the touch. Finally about a week or two ago I was checking the lugs again after a quick drive and completely sheared a stud off. After taking off the wheel and rotor the studs looked completely rusted where the rim sits against the rotor and grooved out like they've been worn down over time. (see the attached picture below). So what do yall think the problem could be? The rims are the original ones from before the restoration. If this was already a thread I apologize, I couldn't find another one covering a similar issue.
