MT Stuff for a guy helping a guy
blazinzuk
Buzzbox voodoo
Rexburg Idaho
Who was helping other guys.
Cole is working in the Dantes peak suburban. Donating his time and probably a bunch of parts he has.
He is looking for some other parts
Looking for 700 harness out of tbi truck. Linkage from column to transmission including bracket on frame. Those strut rods and mounts. Thanks!
I think I may have what you need. Can you post a picture of what is needed? It may take a week or two to pull the parts if I have them though.
I can't necessarily post a picture since I don't have what I need but I will do my best to describe it.
On the transmission (700r4) I need the 4 prong plug and as much of the wiring as I can get.
I need the shifting linkage from the column down to the transmission. This is a rod from the steering column, a bracket that is on the frame, and another rod that goes over to the transmission.
Then there is some maybe 1/2 in diameter rods that go from the bottom of the bellhousing up to the engine mounts. I need those bars and the mounts of possible.
Thanks!
I think I have it. The problem is the frame is now laying on the ground as I have been parting it out. Let me see if I can access it, but it won't be till next weekend at the earliest.
Metrodps came up with linkage, so all I need now is that plug and as much of the wiring as I can get and those rods aND mounts if you got em. Thanks!
Ok so all I need now is that plug and wiring. Haha the list is going down quickly
