Stuff I've learned in the last couple days.
colbystephens
1 ton status
Oregon
I have a friend who's got a '90 Suburban. He threw a rear ring gear tooth through the cover on his 10 bolt on Friday night. All the oil drained out and he drove it about 2 or 3 miles before parking it in my driveway to find out what was happening. :doah: What I was planning on doing was removing the ring gear from the axle and putting the shafts back in and sending him on his way in 4 wheel drive until he had the cash to get a new rear end. When we went to pull the carrier out we found that stuff had gotten so hot in there that the big pin in the carrier couldn't be removed, as it was somehow fused to the carrier. Additionally, the set-screw bolt that holds that pin in place had broken off at the neck-down at the end of the threads. :doah: I didn't know much about how the axle shafts stay in the axle housing on a semifloat axle, so I just cut the carrier with a grinder to pull it out. Well damn if I didn't think about how I would then have no way to hold the axle shafts in... :doah: :haha:
So I found a new axle for him for $100. We went and picked it up. It's a gov-bomb. :doah: Oh well. For a $100 to get him on his way, no biggie. However, the seller had cut the e-brake cables, so we had to pull the axle shafts to remove the e-brake cables, so now I've learned how to remove the axle shafts in that style of rear end too. :D
Dang. I am glad I have a 14 bolt full float axle. SO much easier on so many levels. :D
Started raining real hard, so we called it a day after getting his old busted 10 bolt out and prepping the new one. The new one gets installed Wednesday. Pretty easy swap, and everything essentially went according to plan which was a nice unexpected occurrance. :D
So you jumped straight into ff rear axles and never had to mess with a semi float?
:eek1:
Not good man, you have to climb one step at a time.:D
Yeah that silly 1/2 ton stuff!
That stuff gets hot with no oil fast. I had one is high school once similar thing happen. It started making noises so we got out to look. The housing was glowing around the pinion :eek1: Hauled ass home and let it sit. That housing was junk. Pinion, bearings, and housing forged together forever :doah:
Smart guys we were replaced it with another 10b. Only took us 3 to figure out the bigger axles bolted right in :woot:
:eek1:
:D I know. :) When I originally got my blazer it had no gears in the rear end. I decided to just put 3/4 ton in right then and there. Never looked back. Glad I did too. What a pain in the ass to change an axle shaft on a semi-floater!
For his sake, I would've rather seen him switch to 3/4 ton gear at this point, but his money situation isn't good so getting new wheels and a new front end (or parts to convert) for the 8 lugs wouldn't have worked. I'm also glad I don't have to do as much stuff to his truck. :D This is a bigger project than I'd like to take on for his truck, so I'm glad I'm not doing the front end too. He doesn't know much, so I'm the instructor, which is nice because I mostly stand back and tell him what to do. :D :haha: :D
Hope the gov-bomb holds up. I didn't want to have to search out another axle, so I just told him to run it. I don't think it'll be a problem in his stock pavement pounder... unless he runs this one out of oil too! :D
Sounds like a busy weekend, but in a good way. Speaking of which, my lift and carb are on their way. Next weekend should be fun!:woot::woot:
I learned how to disassemble, rewire, and reassemble an 8274 this weekend. That was fun too..
the broken bolt in the cross shaft sure brings the suck!!
I broke mine on my oldd 88 pickup, it took me a month of part timing it to get it out... drill from the outside, and used an air hammer to beat the shaft back & forth to break the bolt off internally. I yelled with joy when it finally came out!
When I was in HS (mid 90's) there was a guy a grade or two ahead of me who had a nice 70's shortbed K10 with a lift and 36" Swampers. Hot small block. Bone stock axles. He and his dad had restored the thing and built the engine, put the lift on, and off he went in a cloud of tire smoke and mud.:doah:
Kept blowing up rear axles. Couple 12 bolts so they put 10 bolts in "because they were newer". Blew those up too.
Being that I didn't know **** about anything at the time I was as confused as they were.
Hindsight is 20/20.:rolleyes:
btw you dont need to remove the axle shafts to change the ebrake cables, sure it helps to have the room, but still do-able with them in.
I figured that was probably the case. Since the axle was out and all the gear oil drained, cover off, etc., it just made sense to do it this way for sake of ease.
