STUPID 14bff disk brake question
85mudblazin
Austin,TX
Which way does the mounting bracket go, lean to the rear or lean to the front??
Thanks
-CHris
I have my SKY brackets leaning towards the front, which puts the bleeder directly on top. I don't know about the DIY brackets though
You can lean them forward or rear ward depending on whether you use the left on the right and so on. I don't see it making a difference swapping sides. I prefer them in the back leaning rear that is. It keeps them more protected and keeps the hoses behind the axle housing. Look at the front I believe they are the same in the front. Leaning rear.
