Stupid dash lights went out...
reddog64
Federal Way, Washington
They just decided they didnt want to light up anymore...
I checked the fuse... it's fine....
The dash lights, and the heater lights dont work... blinkers still work, and the high beam indicator still works... ????
WTF?
replace the headlight switch. the one in your dash that you pull to turn the lights on. LMC has em.
i had this problem a while back...had to do with the headlight switch connection being loose...check that before you buy a new switch...i ended up buying a new switch and it still did it with the new one...when i figured out the problem i eventually solved it with a zip tie...
Later
