I have a seriously confusing problem here. I have a 97 4wd yukon as my dd, and when its wet out the fugger stalls out and doesent like to stay running. it will chug at around 300 rpms while in park and then turn off, or it will be in drive under no load and turn off. its fine under a load.
My check engine light is usually on for a trans. slip, but when the truck cuts out, the check engine light will stay off for a while.
Im thinking IAC vavle, but dont want to throw $90 out the window if that might not be the culprit.
