badmix
What size/kind/brand for my K5 Blazer, w/ 2" lift and 33s
12 ton harbor freights
agree also, since they get the truck high in the air
lol, before I scrolled down I thought you were serious.I'd go with either stacked cinder blocks
Half of my family owns homes sitting on cinder/concrete blocks from the 60's or 70's... It is not that they can not be used. It is more of a storage solution where you are not working under the rig.
there's absolutely nothing wrong with working under it, other than the bulk of a double pile.. certainly not a safety issue, I work under blocked boats daily that'll dead ya a lot quicker than a car/truck.....
just a peeve of mine... car guys thinking they're smart, "oh, that's unsafe, blah, blah" when it's not the case when done right...
You may have a point. The story I related did indeed happen decades ago. Also it was cinder block, not concrete block so much more fragile.not to be argumentative but ANY cement block has more of a load capacity than is needed... I just mentioned the psi rating for the uninformed.. I haven't seen an actual cinder block anywhere in decades...
doing it wrong is plenty easy and dangerous.
