stupid stupid stupid stupid squeek
tecton
WV
its coming from inside the dash
passenger side
perhaps behind the glovebox
truck looks like a million bucks but sounds like a beater
should i drown it in a pool of wd-40?
It's usually the plastic rubbing on something. Try tightening all the screws. If your going to lube it, don't use WD-40. Use something thatwill last longer like lithium grease.
Try removing the glove compartment, and drive it around. If it does not squeak, then you know it is something to do with the glove compartment. If it does squeak, then with the glove compartment removed it might help you to pinpoint the squeak.
Alpine deck, JL 6x9 3 ways, silk dome tweeters, ALpine amp and RF 10" sub. I hear no squeeks or rattles /forums/images/graemlins/thumb.gif. haha
