I have had similar symptoms from a tank of bad diesel fuel. You can read through the first section of my Suburban thread if you wanna see how the fuel turned out.
I had low power, blueish smoke, and it refused to restart when I parked it (early spring, so still quite cold out).
So don't rule out bad fuel without at least examining it. Especially if it started suddenly.
Setting aside the blueish smoke, a leaky air line on the suction side (allowing air into the fuel system) could cause all the other symptoms.
