T
TankerCadaver
Guest
Hey all,
Previously I owned a 1983 K5 Diesel. It was a great rig but ended up falling short on some duties I needed it to do. My man-cubs are getting bigger and they needed rear shoulder belts for their booster seats. I "figgered" on getting a different fiberglass top w/ belts... no biggie. Then I realized it just wasn't going to have the storage/hauling capacity when the boys were in the rig with me. So, I decided to get rid of it.
I replaced it with a 1996 GMC K2500 Suburban Diesel w/ the 6.5L Turbo engine.
It's in pretty good shape, will haul a LOT of gear w/ the whole family onboard and I think it's going to be the ideal vehicle for me.
It will most likely be a support vehicle for my 1991 XJ Jeep Cherokee (don't taz' me bro') that has been modified to the point of almost needing to be trailered to the dirt. But, I do want to outfit the Sub' w/ a mild lift, tires, recovery gear, etc. so it can serve a greater role in that support position.
So, I've searched around the forums and on the internet. Seems that the 3/4 ton Suburban doesn't lift all that easy with the Diff' IFS set up. Minimum lift looks to be around 4" or 4.5". Does this seem right?
Also, it appears that WITHOUT a lift, my 3/4 ton Sub' would only support tires in the 31" to 32" range... correct?
Any suggestions on a winch bumper?
Thanks for any help you guys can provide. I'm looking forward to getting started on CK5 Forums again... this time as a Sub-Culture member!
on the burb! now post some pics!
