I have pulled the barn doors off the back of my 86 Suburban due to two reasons. 1.) I am getting exhaust fumes in the cab and I think they might be coming in from the back and 2.) they leak water and rattle terribly bad. The seals were hard and brittle and currently have no sealing properties to them. The door gaps on all of my doors are terrible but the back doors were especially bad. The doors are nearly touching the left and right side of the body, just barely not rubbing. I removed the doors with the hinges still attached to doors. I really don't see a good way to shim the door out. There is no way I can see to get the shims in and bolt the door up at the same time. Nor can I find any shims that fit these hinges. My thought was to glue some washers on the hinge with some Gasga cinch and try to insert them with out knocking them off. Am I missing something here? Any help is appreciated.
