klowninc89
I have a1994 1500 suburban 4x4 with ABS. It just started doing weird thing....I hear the ABS pump working when not sliding. And does it under normal load. Light load. And is kinda hard to stop.....could it be the pump?
I've taken a brake class where they talked about ABS on Suburbans... they didn't have much good to say, but you can pull the fuse. That was the "fix" they talked about.
I haven't seen one in person, but I'm guessing if it only has rear wheel abs, the sensor is in the diff (in the pumpkin). If it's front & rear, there should be a sensor at each front wheel. It might be hard to do, but there is a "tone wheel" at each hub with teeth, and the sensor nearby. Check to make sure the teeth are clean, as they said in the class that dirty teeth can contribute to ABS issues.
Good luck. If all else fails pull the fuse![]()
