suburban tailgate window, same as k5?
dsmd58
Does anyone know if the suburban tailgate window is the same dimensions or would work with the k5 tailgate window? Someone vandalized my rig today and broike the glass :mad::mad::mad::mad:...now Im stuck trying to find a replacement!!!
As Scott said, they are very different. I have one at my house currently that I pulled to use in my Blazer, then found out that very little on a Sub tailgate will interchange with the Blazer. None of the regulator will interchange, the glass is also a no go, the tracks are different, but the inside handle will work.
Suburban window openings are about 1.5" shorter than a Blazer setup.
Although the two tailgates are totally different, there are parts guys who inexplicably believe them to be the same, so you might want to double-check what they try to sell you.
